handye9
Feb 06, 2015Explorer II
Here's a link to an installation video. Maybe you'll get enough info out of that.
It's a lot like R&R of toilet in your stick built house.
Disconnect water feed line.
Remove the one nut on each side of the base.
Lift toilet out.
Be carefull while changing the blade seal. The parts up inside there, are spring loaded. Very easy to lose a part or two. Also, it's quite messy up in there.
Lift toilet out.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
