rockhillmanor
Feb 06, 2015Explorer II
Skid Row Joe wrote:
I've got an Aqua Magic toilet, circa 2002 in my Class C that won't hold water, so the seal must be worn out. Are there any how tos on the Net for how the toilet is R & R'ed? Also, are there sources for the seal-kits aftermarket on the Net? Thanks!
Before you jump to 'it must be broke'.......
99% of the time there is some minute small piece of tp paper stuck in the small place that blade has to go into preventing the blade to close tightly enough to prevent the water from leaking out.
Hold the blade open and take a soft brush and clean around the opening. Add a little bit of Vaseline to the blade and seal.
You just might find out you do NOT have to replace it.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
