Gjac
Mar 29, 2015Explorer III
I think it is easier to remove the toilet and put it on your work bench. Mine is a 1996 after doing all the simple things like cleaning the groove,treating the seal it still would not hold water. What I found was a lot of mineral build up from hard water on the under side of the blade and it's encasement, after scraping the build up off,and cleaning the seal with a tooth brush them wiping with Vaseline, I reassembled it and it has held water for the last 2 years. With all that build up a new seal would have still leaked. If you turn the toilet upside down it is very easy to see how it comes apart.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
