duggram wrote:
maillemaker wrote:
1) The tank is not draining. The way to verify this is as was said above: Simply open your drain valve with no hose hooked up, have someone flush the toilet. Water should come out of the waste gate. If no water comes out, you have a blockage.
Steve
Steve, I can't do this:
The toilet has sewer water in it. I'm not disconnecting the sewer hookup line and flushing the toiet.
Use a bucket - you *need* to see what's happening...
The one thing that I've heard of is the plastic round disc that is cut out of the tank to add the outlet pipe sometimes is left in the tank and can then try to come out with a dump and clog the opening.
Good luck!
