duggram's avatar
duggram
Toilet won't flush
Yesterday I did my weekly tank drain (I full time) and both black and gray made sounds and felt like they flushed. This morning my toilet is full of sewer water. I turned the water off to my trailer so I could flush without adding water to the problem. I then gently stuck a broom handle down the hole and met a solid surface.
Does anyone have a suggestion on where to start to fix this?
  • go up on the roof and check inside the black tank vent stack.. it's prob clogged with an insect or bird nest, or there's a forign object in your tank blocking the outlet drain, like a piece of wood from the factory (seen it before) or a feminine product (those are no-no's in an rv toilet).
  • Open black tank dump valve ...then have someone flush toilet/hold toilet open
    See if black tank drains more out of it.....clogged tank vent/toilet open provides venting
  • What kind of toilet do you have? Do the tanks seem correctly aligned when you look under the rig?
  • How far down did the broom handle go; just inches after the hole, or a foot or two before bumping into something solid?
    Another question? Do you ever flush your black tank out after dumping?
    Just trying to figure out where the blockage is actually occurring?
