vandave
Jun 14, 2018Explorer
Torque size
Can someone please tell me what size torque fits the oil change access on the on an 4000 generator. Thanks. None of mine seem to fit.
vandave wrote:
Torn, it was late and I spent an hour trying to find the oilmfilter location. Thanks to you people, I never would have found it SINCE IT DOESN'T HAVE AN OIL FILTER???DUH, I feel,so,stupid.
Chum lee wrote:vandave wrote:
...and the nut is 12mm. I put TORX and mm size with a permanent marker on the small access plate for this fall.
I just talked about this exact issue in another thread. I suggest you trash can the torx screws and replace them with metric hex head cap screws. (unless you're worried about someone (a terrorist maybe) tampering with the oil drain plug on your genny.
Chum lee
mike-s wrote:
Size torque? 4000 generator?
Say what?
Simply guessing you're asking about a bolt head size, get a ruler or tape measure and consider that it may be metric.
