Just_Jeff's avatar
Just_Jeff
Total Electrical Failure After Starting Generator
Has anyone had this happen before? Any recommendations on fixing it?
Yesterday I went to the RV for a tool and decided to do the monthly of cycle the generator. Here's what I did:
- Turned on the main house power switch
- Turned on the factory-installed inverter by remote because it tells me how many volts the batteries are reading. It said 12.8v. I turned off the inverter.
- Primed the generator by the factory-installed remote switch. It primed, the switch turned red like it's supposed to, so I pushed start.
I heard a thunk...I think it was the generator turning over once, and then nothing. Here are the symptoms:
- No power in the house OR the motor. The only connection between the two should be the auxiliary start switch that lets me start the motor with the house batteries if the motor battery dies, and that wasn't pushed. Even the electric door locks don't work.
- Generator won't prime or turn over even when I use the switch ON the generator instead of the remote.
- RV motor won't turn over. I tried it normally and using the auxiliary start switch, and nothing.
- I checked the inverter one more time and it won't turn on.
I've only made two changes to the electrical system so far.
- New batteries. They use the same battery-to-RV connections as the factory.
- Ran an inverter off the batteries to its own outlet inside the RV. It isn't connected to any of the RV's circuits.
Some of you may remember my previous threads where I bought a whole-house inverter, but real life got in the way and I haven't installed it yet so no changes have been made to the factory electrical system except the new batteries.
To do for today:
- Check the fuse box. (Wasn't convenient yesterday.)
- Check each battery with the voltmeter to see if there's a problem with a single battery.
- Check for critter chewing underneath. We have possums around here, and mice outside, etc.
Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
