Vic_Bc's avatar
Vic_Bc
Total Rewire - Trying to understand the process
Hi guys,
So I am putting in a new sound system next weekend as well as getting my lifeline L16T's wired in but the shop said they were able to do all the wiring and weld up a rack for my batteries so I'm pretty stoked on that but I just want to make sure I have everything I need and I want to make sure they are doing everything correct as well. Just trying to understand the process.
1) First thing is first, they suggested I get a cheap AGM for my starting battery as my house bank will be AGM. Some people say it's not needed and you can have a flooded battery as the starter but I figure if I can get a cheap AGM it wouldn't hurt.
2) I just installed two 95W solar modules wired as the following:
Solar panels --> Solar controller/regulator (also displays battery charge) --> batteries(not installed yet) --> Inverter fuse --> 1000W Inverter.
Now I have an old power center installed and am hoping to orderThis charger tonight and have it wired in when the batteries and sound system are wired in. From what I hear it's easy enough to just disconnect the 120V wire from the old converter and hook it up to the receptacle on the new deck mount? I just leave the converter in the power system and I have room in a cabinet above for the new deck mount.
Now I'm sure the wire will need to be replaced. I don't really know much about wiring but here is a picture of my old battery
There's two orange wires coming off the positive, Green coming off the negative. Then there is a red wire which the two little wires inside the red wire go to the positive and negative.
There's a ground spot inside the cabin.
I'm also a little confused as in my power center there are a bunch of wires where I'm not really sure where they lead.
Anyway, what I know is the old battery is charged by alternator which I'm sure one of these cables has something to do with it. And the converter.
Which leads me to my next point.
3) They recommended I get an isolator. I'm not really sure what I'm looking for in battery separators. There is This one on the same site I will be getting my converter but I feel that might be a little expensive for an isolator? Not really sure where it is installed but I'm sure the guys will know.
4) Now when my friend installed the solar package he said I could just run an extension cord from my male shore hookup to my inverter to power the outlets inside. You guys here told me that's all cool as long as I turn off the converter. I'm still a little confused on what a transfer switch does. From my understanding it powers the outlets from the inverter when not plugged into shore power, and shore power will power the outlets when plugged in. Which would mean I don't have to worry about turning off the converter?
I'm not sure how it's wired in at all, or if I need a 30Amp one, 50 amp one, etc? My Male shore power cord seems to be a 30Amp one, with an adapter for 15amps? Does that sound right?
So would all I need is a 30amp transfer switch? Like something like this one?
5) I'm still waiting to hear back from the shop, but when we first talked they mentioned something about a switched power source to the stereo. Not sure if anyone can spread some light on what they were talking about.
  • Helpful general interactive Flow Chartconcept for RV Electrical systems.
    Great little Project you have going. Thanks for posting the process with photos.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
