dougrainer
Dec 12, 2015Nomad
mchero wrote:
This system uses different probes. As stated above, I had a Pace Arrow DP for 12 years and been thru all the tank probe issues once before thanks.
If it has the glued on sending units on the outside of the tank, THOSE can also cause false readings from in tank build up of oils and sewage. Also, ANY type of support and structure within 5 inches of those sending units can cause false readings. Doug
Is this your sending units?
http://www.amazon.com/Touchsensor-100600237-06-Fresh-Water-Assembly/dp/B00ODJ6CC4
