anon125's avatar
anon125
tow haul feature.
So we keep forgetting we have poor memories!
After crossing the siskiyou pass again we remembered the mh has the tow haul feature.
What difference does it make?
We tow a 1997 honda crv.
Thanks all.
  • The tranny will never see "overdrive" in tow/haul mode.
    In mountains, the tranny will shift a lot less, and last a lot longer.
  • And, the tow/haul setting locks the torque converter earlier in the shifting to reduce transmission fluid heat buildup.
  • Assuming your MH works like my truck (is that possible)? When in tow mode two things happen. 1) your transmissions shifts at a higher RPM, giving you more torque to pull up-hills without degrading your speed.
    Second, if going down-hill, the opposite will occur. Tow mode will prevent the transmission from up-shifting, causing you to go faster and faster and faster, causing you to constantly ride the brakes or manually down shifting.
    I know my truck is not a MH, but even when not towing, tow mode is nice in the heavy hills or mountains (well, if you call the Smokeies and the Blue Ridge "mountains" ... compared to the rockies), but .. steep hills are still steep hills.
    So even without towing, tow mode will keep the truck from upshifting into higher gears when going down a very steep incline. Granted, your RPM's will be higher, but you won't have to manually shift back and forth to maintain a steady speed going down hill.
    I love my tow mode now once I actually got into some mountains where I could see it work. Indiana is just too flat. So, no need to use it, unless I'm actually towing. That's when the higher RPM's between shifts is nice (when speeding up).
    Hope this helps ...
Having RV issues? Connect with others who have been in your shoes.24,243 PostsLatest Activity: May 11, 2025
