landyacht318
Nov 04, 2019Explorer
I'd run dedicated wiring so at least your trailer battery gets nearly the same voltage as the engine battery.
The voltage your engine battery gets is decided by the vehicle's voltage regulator, and none of these are programmed intending to quickly and fully recharge depleted batteries.
Mostly they are designed to never overcharge, and as such, will drop to mid to high 13's relatively quickly, but all vehicles will vary in the max voltage and for how long it is held.
Only if your alternator was incapable of meeting all the loads applied to it would increasing its rating prove beneficial, and likely only at higher rpm, not idling.
Likewise a larger better starting battery is not going to assist trailer battery charging.
I'd get the following 6awg harness or similar, and run it to alternator + and a - mounting bolt. Disconnect the connector manually when parked for any length of time so trailer cannot discharge engine starter battery.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
