Matt_Colie
Nov 05, 2019Explorer II
CJM,
Without knowing the specifics of the TV and TT, I fear you are headed for a disappointment. Even if the the TT house bank is on the tongue, we are talking a long run of cable. Remember, to make this work right, you will not be able to count on the frame of anything as a conductor.
With the entire life of a Lead/Acid battery between 12.0 and 12.6, and peak charging limited to 14.4 (or .6), there is no room for voltage drop. So a huge alternator will be a lost cause even if you run welding cable from the alternator to the house bank.
A Renogy charger will be a big help, but you are still stuck with the recharge time being limited by the battery chemistry. Even AGMs, though will charge faster, still have limits. They just get to 90% a lot faster if you can feed them juice.
You do not say what the installed converter is in the TT, but if it is not a modern 3 or 4 stage unit like Progressive Dynamics or Iota (there are others now) that does a boost, bulk and float, I suggest you replace it first.
Then, go an buy an inexpensive little genset. Try not to buy a "Contractor" unit because they are designed to cover up the noise of hammers and Skilsaws. There are more than a few on the market. Then, you will also have the portable for other uses. (You will find some.)
I know of a guy that boondocks with a long cab TV and a TT that ties his generator down in the bed and runs it when underway. He just runs the shore power cable to it. (With some duck tape for control.)
This will all be more simple and reliable than the alternatives, you will just have to put up with some noise some times.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
