time2roll
Nov 05, 2019Nomad
CJM1973 wrote:I think you want the DC/DC charger close to the trailer battery mounted on the trailer. This puts full voltage right on the battery. Manual says not to connect direct to the alternator... I would connect to the vehicle start battery or for a clean look work this into the main 12v distribution fuse box.
I forgot to ask; if I do proceed with the DC to DC charger, do I wire it directly to the + battery terminal or + alternator lead? The renogy diagram shows multiple methods.
Also, what type of connector is preferred from TV to trailer? Wire will be 4 or 6 awg.
For connectors this set is used for trucks good for 100 amps and up to #4 wire. Truck Camper forum has people happily using this item. Available at NAPA. https://www.napaonline.com/en/p/PHI15336 https://www.napaonline.com/en/p/PHI15326
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
