Matt_Colie
Nov 06, 2019Explorer II
CJM1973 wrote:
Thanks for all the insight first.
Details I hadn't mentioned:
{SNIP}
5. We will be bringing an inverter generator (Westinghouse 4500w/3800w) with us. I don't know how "generator friendly" the Alcan hwy is (or the waterfront campgrounds throughout Alaska). I would rather use it as seldom as possible.
6. I did install a pure sine power inverter (1500/3000 watt) in the passthrough storage bay. Don't know if it's just the brand, but it fails to run the 900 watt microwave. A new inverter may be required as the wife is insistent on that appliance for light meals for the kids. I've been reading that 6 volt golf cart batteries in series don't perform nice with large amp draws verses a similar amp hour 12 volt deep cycle bank wired in parallel. I'm also under the impression that flooded lead acid batteries have different discharging characteristics than AGM batteries. I'm considering an AGM upgrade even though my wet cell GC2s are only a year old.
I'm trying to determine what electrical upgrades are most beneficial without breaking the bank. The DC to DC power charger is top on my list. I'm questioning the long run of cable from the front of the TV to the trailer's passthrough storage. Based on what I'm hearing, I'm going to hold off on the alternator upgrade. The TV's little 600 CCA battery could be changed out for a higher capacity battery. An AGM upgrade to the GC2s is a possibility too. Don't know how I can increase amp hours unless I move to Lithium. The task of defining which components to upgrade (or add) is becoming a challenge. Even though winter will keep the coach idle, June is approaching fast and I'll need solutions before the weather breaks.
CJM,
You are doing this correctly, thinking is THE MOST cost effective thing to do right now.
I do not know about the ALCAN, but most places that do not offer shore power will tolerate a generator outside of posted quiet times.
I have done installations with 2eaGC2s for a microwave and they all worked. If yours won't, then check the supply voltage at the inverter when under load. If it is low, either move it closer to the house bank or buy more copper. I had to use welding cable. It did work and pretty well. Asking the GC2s for 150 amps is a little tough, but most will do it. The good thing is she is not baking a casserole. The good thing about copper is that you only have to buy it once. Welding cable is good for this because it is so flexible.
Best of luck
Matt
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
