grizzzman
Nov 06, 2019Explorer
I have the Renolgy 40 amp DC to DC charger. It has 3 stage charging and is adjustable. The truck input was 50 amps and the output as advertised. That was at 14.0 volts truck and 14.7 volts output. The charger has a trigger that you hook to the ignition switch. Hook to the battery. Do not use any less then 6awg wire (I used 4awg at 20 feet) I had a solar controller issue. Idled the truck for 1 TO 1 1/2 hr, and was able to run anything I wanted,including a 12 cup drip coffee maker. But to be fair, I had installed a 2P4S Lifep04 battery on this trip.(I wish that I had not waited so long to go LFP) What a difference!
Good luck with your adventure!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
