BFL13
Nov 11, 2019Explorer II
Undercharging, not overcharging will be the issue. You need an ammeter to tell when amps are down to 0.5/100AH. That does not mean 1.5a for the bank of three, since the middle battery will not get its full share. I use my Trimetric as the ammeter. You need to do each battery separately to true full as often as possible.
On a trip it is too difficult to do all this right, so it is what it is. At home, you can do it right. See the AGM charging guide here, scroll down
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
