RandandDoug
Apr 21, 2017Explorer
Talked with spartan and on my year moho the same fuses that operate coach lights operate trlr lights. Coach is working properly so it is wiring or a connector somewhere. The receptacle looks ok, but I think I will start with replacing it with a new one in case it has funked out. Doubt that is it but a quick and easy try. Then trace the harness as far as I can.
When using a tester, should I hook the power lead to power and then to different contacts while those are turned on, brake, turnsignal, tail lights and so on?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
