dclark1946
Jan 29, 2018Explorer
If you are certain that your problem started after replacing the switch, the mostly likely cause is that some of the wire connections are not prooperly seated on the switch after installing it. I am assuming the connections were some type of spade lug connection. If you have access to a wiring diagram it would help you determine which connections are suspect.
