okhmbldr wrote:
I'm sorry you're having a problem understanding what I did with a battery an inverter and a portable A/C. What I described is exactly what happened. The inverter would shut off when the battery power was drained too far to proceed. I don't know how all that works. I just hooked it up and it worked for me.
It Is not theory that is wrong
It is the numbers you are stating
One battery is not going to power a 12000 btu
AC for 6 hours
What was the outside ambient temperature at night
How much time did the compressor actually run per hour, 5 minutes per hour maybe 10 minutes,
Mostly just fan time,
Were the cables also connected at night so you were also connected to the boats battery system
Not just the single battery
Was the portable AC  really a 4000 btu window unit
A whole lot less power consumption
