tanman32225
Jul 18, 2013Explorer
it sounds like a common fuel pump problem. The impeller swells from lack of use. I can only repeat what others have done as I exercise mine as a prevention. They disconnect the power to the pump. Take the small bolts/screws out of the pump and remove the impeller. They sand down the sides of the impeller where it rubs the casing. Reassemble and it works.. Others just replace the impeller with a new one.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
