RV_CONUS
May 10, 2014Explorer
X10 TST
Even though the toad has its own tpms, I use tst sensors on the car to let me know if there is a tire problem while towing.
Did a lot of research, and went with the TST, I wanted to be able to change my own batteries in the sensors.
I never leave home without TST.
Almost forgot, TST also gives constant temperature reading. The temp readings are based on sensors attached to the valve stem. An internal tpms may provide a more accurate temp reading, but at least the stem readings are better than no readings. Besides, I can easily move the sensors from one vehicle to another and reset them accordingly. jmho.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
