fj12ryder
Apr 27, 2017Explorer III
2oldman wrote:I just reread this and wanted a bit of clarification. If you take the monitor and walk out of range of the sensors, how long does it take before the monitor alerts you to the fact it is no longer receiving signals from the sensors.fj12ryder wrote:About a minute. The monitor is constantly cycling thru all the sensors, and suddenly one will just show blank. Turning the monitor off and back on will clear it up...for a while.
how long does it take for the monitor to alert you to the fact you've lost contact with a sensor? Have you ever checked the time frame? .
The TST takes about an hour, but it acts just like yours: the monitor cycles through the sensors, but then one will show up blank and an alarm will sound. However, and here's the kicker, it could be up to an hour between when the monitor lost the signal and the monitor alerting you to a lost signal and showing a blank. That's why I was wondering how long yours takes to notify you.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
