PGCR's avatar
PGCR
TPMS - I know, again!! Need some buying advice!
So, I'm at that point where I'm ready to pull the trigger on a TPMS for our 5ver (I know, I'm late, but better late then never!!) and really need some good advice on which system to invest in. I've been really looking at the TST507RV with the 4 Flow Through sensors, but the price keeps creeping up and up. I'm not sure this is the forum to put this in, but thought I'd throw it out there and see what the opinions are with regards to any system that I should be considering. Thanks in advance. Paul
  • I purchased the model 507RV with flow through sensors from TST a couple of years ago. No problems at all, and the system saved my bacon last month when I had a tire going down. The system alerted me to the problem and I was able to pull over to take care of it before the tire was completely flat and started separating which would have caused a lot of damage.
    I wouldn't travel without my system now.
  • Sees to be concerns over flow-through sensors propensity to leak. Once you have a TPMS, you stop accessing the valve stems unless there is a leak, then you know and can get it fixed right away. We've have an EEZTire system on our class A for a year now with excellent results with the non-flow thrus. Agreed that the price has been escalating since we got ours. Usually electronic stuff gets cheaper. Even at the higher price I'd gladly do it again. I'm a firm believer that all RVs should have them. Pretty much all travel in an RV is for a longer period of time than cars. With a car, you pick up a nail and when you come out of the store your tire is flat. With an RV, you drive long enough for the tire to leak down enough to overheat and fail at speed. This is a safety regulation that should become law for RVs as most people don't realize how RV travel makes a blowout more likely than in their car.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
