Jerry_B's avatar
Jerry_B
Trailair pin box traps water causing rust
My 18k Trailair pin box traps water at the top of it just aft of the air valve. Serious rusting is occuring. Anyone heard of a fix for this? Drilling a hole in it isn't feasible without removing the pin box.Thanks.
  • Thanks everyone.I cleaned up the rust the best I could with Naval Jelly. I'll look into drilling holes again.
  • I drilled two holes, one on either side. They are at the front, just behind the wall that traps the water. I spray painted the the area where water gets trapped and it's not really an easy job because of overspray. I also sprayed paint through the holes as best as possible but still have to clear them of debris and rust every once in a while.
  • What I have done...…..buy the small shrink wrap with the handle at Lowes or HD....5" wide and you can wrap the pin box with the wrap.
    Why can't you drill a hole, if it's a question of room there are right angle drill motors or 90 deg adapters. Plus stubby drill bits.
    Otherwise the only thing I can think of is really cleaning down to the bare metal then using good primer then several coats of high quality epoxy paint. The Navy, last I heard, uses 5 or more coats of paint on their ships.
