ekirkland
Feb 09, 2016Explorer
smkettner wrote:
The charge may start a bit higher but 10 amps is about the most you will get.
The best solution IMO is 200+ watts of solar.
Is there a portable solar charging system you can plug in and set outside on the ground instead of having to permanently mount it on the roof?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
