time2roll
Feb 09, 2016Nomad
ekirkland wrote:Roof has a lot of advantages. Including charging while driving.smkettner wrote:
The charge may start a bit higher but 10 amps is about the most you will get.
The best solution IMO is 200+ watts of solar.
Is there a portable solar charging system you can plug in and set outside on the ground instead of having to permanently mount it on the roof?
https://www.solarblvd.com/index.php?cPath=1_272
Also check amazon ebay etc
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
