dclark1946
Jun 15, 2016Explorer
RoyB wrote:
You can also use a campers compass held up close to the brake magnets and you should see the needle deflect when the brake signals are applied.
Some brakes also make a tone noise when activated. Both my trailers do this... You have to be real close the wheels to hear it...
each brake magnet will draw around 3AMPS DC current if the full 12VDC is applied. So add your brake magnets and see if your DC current is close to that number for all brakes... Four brake magnets could draw as much as 12AMPS DC CURRENT when 12VDC is applied.
Roy Ken
Roy. I assume the compass test is with the wheel and drum removed to expose the brake magnet? Does 11 A sound about right for 4 brakes. I think that is about what our old trailer pulled.
