myredracer
Jun 15, 2016Explorer II
dclark1946 wrote:
Another question after crawling around under our new KZ Spree TT.
We have a 2014 version of the same Spree model (except it has the different bathroom layout). I would suggest looking at the wiring in the A-frame area. Ours was poorly done. Plenty of corrosion and water trapped in upside down wire nuts inside the 4x4 metal box. The positive wire from the battery was completely loose in a ring terminal and fell right out when I touched it. You may fix the wiring at the brake drums, but you also need the connections from the trailer's wiring to the umbilical cord to work, especially for braking when you need it the most some day. I completely redid the connections and installed a watertight PVC junction box. I also redid ground lugs to the frame due to corrosion.
The brakes in our TT are not grounded via the axle tube and have 2-wire cable spliced to the 2 brake wires. The wiring is awfully small gauge though and I plan to upgrade it when I eventually take down the underbelly sheeting.
This our 2nd Spree TT and wiring does not appear to be their strong point. Have also found poor AC & DC terminations at the converter/panel (including completely loose wire at a breaker) and a couple of receptacles with reverse polarity.
