Gdetrailer
May 17, 2022Explorer III
ReneeG wrote:
Our problem was in the actual wheel hub. Once they pulled it, they found the problem.
Yes, that is correct as there are pinch points where the magnet wires can get caught and insulation damaged or the wire breaks.
But generally only one out of four magnets being disconnected isn't going to generally cause the controller to point out a failure unless the wire is touching and shorting to the metal or shorting both magnet wires together inside the drum..
Controller doesn't care if there is one or six magnets as long as it gets the ring back from the pulse as expected. Typically you will have two to six magnets depending on axle count so controller has to be a bit flexible.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
