Gdetrailer
May 18, 2022Explorer III
agesilaus wrote:ReneeG wrote:agesilaus wrote:
Logically since this problem is showing up on RAM and Ford trucks and we all have different RV's thus the problem is most likely in the truck connections and/or plug. Especially since it goes away for a time after cleaning the connectors.
We did that too. Cleaned the connector and it "went away" or so we thought. There was just something differently wrong. It was just coincidental that the cleaning seemed to help.
If one person reports 'cleaning' gives temporarily relief then maybe coincidence. If multiple people report that is the case, as it is here, then it is not coincidence. That is not to say that other problems might occur but the most likely is a bad connector on the truck.
I will have to disagree with the thought that all of the problems are from the connector on the truck end.
The socket on the truck is believe it or not, fairly protected from weather since it has a spring loaded cover that snaps closed when the plug is removed. That cover while is not sealed with a gasket stops a lot of moisture from getting to the contacts. So those sockets tend to have a very long life even in the most severe climates.
I have as of yet never ever needed to clean nor replace the 7 pin socket on any of my trucks and I live and drive them in the rust belt with tons of heavily salted winter roads. 97 F250 had 150K miles and had that for 6 yrs, 2003 F250, had 250K miles and owned it 13 yrs (the bed was rusting out but the 7 pin socket was still fine), 2006 F250 140K miles owned it up to 2019 and the bed was rotting off but yet the 7 pin socket was fine, 2013 F250 135K on the clock so far and the 7 pin socket is fine, have 2019 and 2020 F250s and they are fine also..
The problem child tends to be the 7 pin PLUG on the trailer tether cord.. The plug stays out in all weather unprotected.. I tuck mine under the propane tank cover to keep it dry and out of the weather..
Barring a problem with the PLUG, the rest of the problems tends to be the wiring on the TRAILER..
No need to scare folks into attacking the vehicles socket and wiring unless all else fails, most of the problems will be found and corrected on the trailer side..
