cbwallace's avatar
cbwallace
Trailer brakes stop working when headlights are on
My Reflection has developed an issue where the trailer brakes stop working when my headlights are on. In the truck I get a Check Trailer Wiring message. When this occurs the trailer brakes don't work. When I turn the headlights off trailer brakes work again. On may last trip this also happened about 50% of the time I used a turn signal. I have checked 7-pin connector and find no corrosion. I am thinking it is a grounding issue but not sure what to check in the 5th wheel, any suggestions?
Chris
  • I agree about it probably being a ground issue. Did you test the resistance from the ground wire in the umbilical and the frame?
    Look underneath and check/clean/reattach all the ground connections on the frame.
    How about the truck side? Is it grounded to the frame somewhere in the rear?
  • A short somewhere in the wiring? I just spent an afternoon patching my cable after it got some road rash
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
