ppine
Apr 16, 2019Explorer III
Many brake controllers have two adjustments.
One is the magnitude of the pulse to the brakes which is obvious and adjusted with numbers
Not so obvious on many controllers is a little slide adjustment on the side which controls how aggressive the brakes are. Reduce the aggressiveness of your brakes. Look under there with a headlamp and see if you can find it.
