SoundGuy wrote:
SoundGuy wrote:
7-pin Bargman Pinouts ... +12 vdc required on Pin 3 for the running lights to illuminate.
dougrainer wrote:
This is totally INCORRECT. The COLOR coding is not correct. Going to the Internet does not always yield the correct diagram. Doug
Dougie, buddy ... where did I say ANYTHING about colour coding? Read my post again, it says 7-pin Bargman Pinouts ... what is it about "pinouts" you don't understand? I further went on to say (to the OP) that in order for his running lights to illuminate there must be +12 vdc on Pin 3. In other words he needs to check with a VOM whether he has +12 vdc on Pin 3, if not those lights are not going to work. I made no comment regarding colour codes, that drawing is not my own invention, I don't own it, it was intended merely as a convenient means of illustrating 7-pin Bargman PINOUTS. Good grief. :S
The REASON I stated what I did was, some yahoo will look at your incorrect drawing and then take the 7 way apart and think that the wires(colors) are all on the WRONG pins. If you want to post a PIC, PICK the correct Picture. Doug
