Bobbo
May 12, 2017Explorer III
WE-C-USA wrote:
I got everything the way I want. Moved the hot gen/inverter wire from L2 to L1. Transfer switch worked without jumper. I then reversed the L1 & L2 ( Black-Red) to the control panel (output) side.
How I only power the things I want too.
The main reason I don't want to power one side, it has- Water Heater-AC-Convertor & some outlets, things that are not used while using the 2000w inverter. I wanted the converter off while using the inverter/charger/generator. I use a Honda 2000 mainly to recharge batteries.
WE-C-USA wrote:Bobbo wrote:
I can't help wondering what the downside is for powering both sides. You don't have to USE the other side.
Yes I could power both sides. Then while using the inverter, I'd have to either--turn the Convertor circuit breaker off or install a relay. You don't want to run both at the same time.
This is the first mention of an inverter. You kept saying "generator." That particular detail would have aided those trying to help.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
