- brulazExplorer
MEXICOWANDERER wrote:
My choice :)
http://www.ebay.com/itm/MAGNECRAFT-92S11A22D-120A-Enclosed-Power-Relay-30A-120VAC-DPDT-/331326301626
Easy to use FULL 30 AMP RATED. Use fully insulated YELLOW 12-10 Fast-On type connector terminals. if need squeeze terminal before slipping onto tang to insure a TIGHT slip-on joint.
But that's only 3A rated on the NC contacts. - brulazExplorerIs a double pole switch necessary?
My current switch is, so both hot and neutral are switched.
But have wondered whether neutral couldn't just be passed thru, like ground currently is. - MEXICOWANDERERExplorerMy choice :)
Easy to use FULL 30 AMP RATED. Use fully insulated YELLOW 12-10 Fast-On type connector terminals. if need squeeze terminal before slipping onto tang to insure a TIGHT slip-on joint. - KD4UPLExplorer IIManual or automatic? For manual 15A 120v transfer switch you can use a regular household 3-way switch. They cost less than $2 plus a 25 cent box to put it in.
I'd upgrade to a commercial grade switch though, it will still be less than $5. - You can get just a toggle switch 120v 15a rated but it needs a box too.
15a automatic:
http://www.donrowe.com/KISAE-TS15A-Automatic-Transfer-Switch-p/ts15a.htm - Joe417ExplorerI ordered a 30 amp WFCO last night for $25 + $10 shipping. 2 year warranty. The next cheapest last night was same unit for $45 with shipping. I think it was 5 x 5 x 5.75.
Haven't looked at anything smaller. - hedgeExplorerI'm using this one, seems to work fine. Not sure it's the absolute cheapest.
https://www.amazon.com/Xantrex-8080915-PROwatt-Transfer-Switch/dp/B004S5Y158/ref=sr_1_1?ie=UTF8&qid=1495208622&sr=8-1&keywords=xantrex+transfer+switch - 2oldmanExplorer II
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
