Slownsy's avatar
Slownsy
Transfer switch
As som off you know my MSH3012 inverter won't pas true power so I have to have a bypass switch installed. The electrician her in Australia are not clear on how to do this so can someone please supply a skematic or good explanation on how to do this so that I can have power going from power board and back from inverter or bypassing it without backfeding to inverter. Thanks.
Frank.
  • Slownsy wrote:
    It is because in Australia we only have 50hrz so switch won't close.
    Frequency (50Hz vs 60Hz) should have nothing to do with the relay pulling in.
    Contact the manufacturer.
  • It is because in Australia we only have 50hrz so switch won't close.
  • Sounds complicated, what's wrong with the inverters own transfer switch? Isn't it dual 60amp or some such?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
