n4hwl's avatar
n4hwl
Transmission fluid additive in the hydraulic system
I wonder if there's a transmission fluid additive that would soften the seals on the jack cylinders without hurting anything. Has anybody ever tried this on HWH system. I have a left rear jack that is moving slowly going up. It's still working and transmission fluid on the cylinder before it goes up does help a lot. I know it's a matter of time before I have to get another cylinder but just trying to prolong is life.
Ken
  • This is a hairball grade better than nothing band-aid for a leaking hydraulic cylinder seal. Directions must be followed exactly to the letter or total cylinder seal failure will occur.
    Brake fluid. Any.
    Cloths (2) both clean.
    Wipe extended protruding cylinder shaft to clean off hydraulic oil.
    Wipe on a THIN coat of brake fluid to the exposed cylinder shaft. Careful! No drops, no slops.
    Now retract the cylinder shaft.
    Wait 3 hours.
    Extend the shaft.
    Did this reduce the amount of leakage?
    Brake fluid swells neoprene. But I warn you, this is a tourniquet not a health spa treatment.
  • I was talking about an additive I could add to the fluid reservoir and have it soften the seals. I would hate to add something to the fluid and have all 4 jacks quit working. I guess the safe way is to just keep the cylinders lubricated from time to time.
    Ken
  • This is a question senor westend, not a comment or a critique of your response...
    Is not extremely fine emery cloth referred to as "crocus cloth"? I would like to re-learn this as I have projects that would love to see "fine emery cloth" and wish to know for sure if the term "crocus cloth" would succinctly define what I need to a hardware store employee north of the border.
  • Extend the cylinder with no load on it to the maximum travel. Using fine emery cloth, polish the exposed piston. Wipe down with solvent to remove any sanding dust. Oil piston lightly with a lubricant that doesn't deteriorate plastic or rubber (motor oil works well and this eliminates WD-40 as a lubricant).
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
