westend
Jun 18, 2017Explorer
Extend the cylinder with no load on it to the maximum travel. Using fine emery cloth, polish the exposed piston. Wipe down with solvent to remove any sanding dust. Oil piston lightly with a lubricant that doesn't deteriorate plastic or rubber (motor oil works well and this eliminates WD-40 as a lubricant).
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
