skipnchar
Jun 14, 2013Explorer
Most likely you just need a MUCH better battery. If you're using a "marine/RV deep cycle battery, then this is little more than a modified starting battery. These batteries will not withstand very many deep discharges so when you ARE using them for dry camping you are MUCH better off to recharge them daily rather than deeply discharging them before recharging again. The Marine/RV deep cycle battery works pretty well for someone who stays in campgrounds or RV parks with electric hook ups MOST of the time since the battery is kept nearly fully charged.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
