the_bear_II
Sep 05, 2019Explorer
My first thought was- Could it be an alien space ship in disguise?
If it is plugged into power I guess it's possible the roof may be creating some sort of jamming. But that would mean there would have to be some current going through the roof which means a possible short. First thing I would do is to unplug it from power and if you have solar panels disconnect them.
I remember reading where a motorhome became charged with electricity when it was parked under some high power electric lines. The owner would get a small shock when he touched the skin of his MH. Once he moved the MH out from under the power lines the shock went away.
Do you have a Cell signal booster or WiFi extender they shouldn't cause interference but if the frequencies are close who knows what might happen.
I would unplug all electronics and disconnect the batteries in the trailer and then start reconnecting one by one to see if any are causing the problem.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
