naturist
Jan 11, 2014Nomad II
Circuit breakers get a little weaker every time they pop, so it is likely that they need replaced. In normal service, they are not supposed to ever pop, unless there is a serious problem. They will last for decades if never used.
On the other hand, if you pop the same one twice, you DO have a serious problem. It sounds like you may be overloading the circuit. A 1500 watt heater will, all by itself, take 12.5 amps of what are usually 15 amp circuits, especially on a rig that only has 30 amp service in the first place. That will leave at most 2.5 amps on that circuit for every/anything else. 2.5 amps is only 300 watts, which is half a coffee maker, or half a water heater, or half a curling iron/hair dryer.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
