Mike_LeClair
Jan 25, 2014Explorer
Hello All! I just wanted to keep this thread alive and apologize if i am thread hijacking. My brother and I are in Earp, CA at the Big River RV Park until Canada warms up a bit. We have similar RV's, although his is a 30 amp service and ours (bride and I) have a 50 amp service. Just yesterday his breaker for the water heater started tripping off and would cause the main breaker to pop almost instantly. We replaced the old element with a brand new one and the same thing in happening. We then turned off all of the breakers, then turned on the main and then only the water heater breaker - the w/h breaker immediately tripped off along with the main breaker. Clearly there is a fault here that is specific only to the w/h circuit. How can I troubleshoot this problem or is it as simple as replacing the breaker? As long as the w/h breaker is off all of the other services and devices run just fine.
Thanks for reading
Cheers!
Mike and Carol
Thanks for reading
Cheers!
Mike and Carol
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
