ktmrfs
Oct 29, 2022Explorer III
TomC71 wrote:
I have a 23' Terry Taurus. I'm almost never going to use it hooked to an AC power source, and want the AC plugs to work off an inverter I have.
Is there any reason I can't hook the inverter into the system somewhere to do so?
depending on the inverter you may be able to add a transfer switch to go between AC power or inverter power. That's what I've done.
Hint: if you do so make sure the charger is turned OFF!!!!! when the inverter is on. Otherwise the inverter will try to charge the battery, and endless loop down a rabbit hole.
