time2roll
Oct 29, 2022Nomad
TomC71 wrote:Yes. Easy to connect a small inverter maybe 300 watts max. This will run or charge most small items.
I have a 23' Terry Taurus. I'm almost never going to use it hooked to an AC power source, and want the AC plugs to work off an inverter I have.
Is there any reason I can't hook the inverter into the system somewhere to do so?
Mount behind the breaker panel, use the main 12v feed for power in, and a small transfer switch to connect to each branch circuit as needed.
Be aware of mixed connections such as the fridge and converter. May need to disable these or in the case of the fridge set it to propane only.
Large inverter would need to be closer to the battery and involve pulling wire.
(and yes I have a 300 watt GoPower inverter installed like this)
