StirCrazy
Oct 31, 2022Moderator
TomC71 wrote:
I have a 23' Terry Taurus. I'm almost never going to use it hooked to an AC power source, and want the AC plugs to work off an inverter I have.
Is there any reason I can't hook the inverter into the system somewhere to do so?
I have my 5th wheel set up like that, it is wired directly to the ac side of the fuse box, well almost, I use a transfer switch which automaticly disables my charger when the inverter is active.
Steve
