ewarnerusa
Oct 31, 2022Nomad
enblethen wrote:
Could install a 30TT receptacle fed from the inverter, adjacent to the shore power cord, plug the cord into it. You must disconnect or turn off the converter...
No need to install a 30 Amp outlet, just plug your shore power cable with dogbone adaptor to standard AC plug directly into the inverter. Our inverter is installed in a location where I can conveniently do this and that is what we do. Converter switched off via AC panel - I have it on its own breaker. I also switch off air conditioner and water heater on the AC panel to avoid accidentally energizing them when running on the inverter. We 100% boondock and have been running it like this for 10+ years.
