3_tons
Oct 31, 2022Explorer III
wolfe10 wrote:enblethen wrote:
Could install a 30TT receptacle fed from the inverter, adjacent to the shore power cord, plug the cord into it. You must disconnect or turn off the converter.
How are you going to charge the batteries/
I would NOT recommend that.
You only want to enable some outlets/appliances to be able to run on the inverter. Certainly not the roof A/C.
Yes, the "details" on the wiring depend on the inverter you choose. Many have a "pass through" feature, so if it receives 120 VAC from shore power or generator, it does not invert, merely "passes the other source through.
Cleanest way is to either use a sub-panel downstream of the inverter with only those things you want to power from the inverter. Need to move not only the hots, but neutrals and grounds from those circuits.
As you get closer to choosing equipment, give us details on that as well as what battery bank you have and what you want to be able to run when on inverter power/dry camping.
BINGO! When running from the inverter the sub-panel sequesters certain items (like the air conditioner, water heater, onboard converter-charger, refer, as you see fit) from the inverter’s output - this method prevents the ugly, sure to occur event of an inadvertent battery drawdown…Based on your particular enquiry my recommendation would be a pass-thru type pure sine inverter or pass-thru inverter-charger combo (both having a built-in ATS) of at least 2000w (e.g. microwave capable)…JMO
3 tons
