TomC71
Oct 31, 2022Explorer
3 tons wrote:TomC71 wrote:
Is there any reason I can't just take the wire coming off the breaker for the plugs and it's negative of course, and hook them to my inverter and skip what it seems a lot of people have done?
As I said, I am just looking to power the plugs in the trailer.
I have to look to see if I have the wiring diagram for it and see if the plugs are isolated from everything else or part of another circuit.
First off, no doubt, just about anything that folks can think up has already been tried (with varying degrees of success and failure…)…The method you suggest (without a ATS) would create a electrical hazard if you forgot the inverter was ON and started the genny or plugged in to shore power, nor would it allow you to run the microwave since it is on its own dedicated circuit…Rules are just a consequence of mistakes - Rather than rely upon memory, you should plan on having an approved means of isolating the inverter from shore and genny power.
3 tons
This was the sort of thing I was referring to when I mentioned people making assumptions.
We've lived in a travel trailer since last year, 100% off grid. We do not use a microwave, don't use the furnace, A/C unit and don't have any high power draws at all. We power our lights, radio and charge our phones, tablet, laptop and internet hub. Our 'new' trailer, is the same year, just a slightly different configuration of trailer. It doesn't even have a roof top AC/furnace unit in it.
That was why I said I was looking for a way to power the AC plugs (which is not the A/C plug...)
I want the AC plugs working so we can plug our phone/tablet/laptop in to them to charge them.
As for the multiple comments about 'forgetting it' when hooking it up to shore power, either with a generator or shore line, we have literally never, not even once, hooked either to our trailer. The very, very rare occurrence (twice last winter), when we used our generator, it was to charge the batteries up when we had a few too many cloudy days in a row.
