TomC71
Oct 31, 2022Explorer
3 tons wrote:
Recall the old sage advice regarding ‘assumptions’, and you should consider that this goes in both directions!! - Given such a limited but evolving description, are others to merely assume your specific scenario, or level of competence - Really??… Either way, you’re very welcome (lol!), and I’m sticking with the previous advice for the larger audience as follows,
“Rather than rely upon memory, you should plan on having an approved means of isolating the inverter from shore and genny power.”
3 tons
You already DID make assumptions, as did others. Now when I clarify why those assumptions are totally wrong and pointless, you whine?
Have you ever tried asking questions instead of making assumptions?
"Hey Tom, what are you planning on powering through the plugs?", "Do you ever plan on being hooked to shore power?", "Could you tell us more about your set up?"
Or you could, as you did, assume you know everything you need to and offer suggestions based on those incorrect assumptions.
