StirCrazy
Nov 02, 2022Moderator
time2roll wrote:TomC71 wrote:Yes that is what I suggested but with a small automatic transfer switch to make it user friendly for all that might need power.
Is there any reason I can't just take the wire coming off the breaker for the plugs and it's negative of course, and hook them to my inverter and skip what it seems a lot of people have done?
As I said, I am just looking to power the plugs in the trailer.
I have to look to see if I have the wiring diagram for it and see if the plugs are isolated from everything else or part of another circuit.
but if you are using a auto transfer switch wouldnt that just replace the main supply wires coming into the power center.. seams overly complicated to use that then wire it to a breaker.
